言語
The GoodWe BH Series inverter is a single-phase, AC-coupled retrofit inverter compatible with a wide range of high voltage batteries from 85V to 450V. It is designed to maximize self-consumption with UPS-level switching backup function. The pre-wired communication cables and AC connector’s ‘Plug & Play’ simplify installation, operation and maintenance.
Maximize self-consumption
Pre-wired communication cables
Plug & Play AC connectors
Hybrid systems converted
<10 ms UPS-level switching
Compatible with various high voltage batteries (GoodWe, BYD, Pylon, etc.) Flexibility and affordability to fulfill different customers’ energy storage requirements.
Pre-wired communication cables greatly shorten installation time. Plug & Play AC connector simplifies O&M.
Compact design
GW3K-BH
85~400
Max. Charging Current(A)
32
Max. Discharging Current (A)
32
230
Protection Degree
IP65
GW3600-BH
85~400
25
25
230
Protection Degree
IP65
GW5000-BH
85~400
25
25
230
Protection Degree
IP65
GW6000-BH
85~400
25
25
230
Protection Degree
IP65
ニュースレター
ジョイトゥインストール
