言語
GoodWe three-phase smart meter GM3000C has been designed especially to calculate PV system electricity consumption and demand. It is equipped with 3 sets of external CT and is used for grid systems with neutral wire. The CT ratio can be set in the SolarGo app. Trough RS485 communication, any GoodWe three-phase inverter can connect to the GM3000C and achieve export power control. With a larger detectable range of voltage (100Vac-240Vac) and current, it is the ultimate cost-saving solution for PV systems with large load consumptions.
Wide voltage input range
Large detection range of input
Export power control
Easy installation with external CTs
Configurable CT ratio via APP
Fully compatible with SEMS Portal
GM3000C
Application
Three-Phase
Voltage
230Vac
Current Range
1A (5A)
Self-Consumption
<3W
Protection Class
IP20
ニュースレター
ジョイトゥインストール
